2023-04-22 |
201 |
5.5 |
36.55 |
"Getting warmer!!" |
2023-05-14 |
504 |
12.8 |
$3.42 |
39.38 |
"Installed Kammback" |
2023-05-19 |
400.5 |
9.78 |
$3.39 |
40.95 |
"Installed rear air splitters" |
2023-06-11 |
406.5 |
42.34 |
"Mixed city and Hwy driving, with A/C" |
2023-06-21 |
251 |
5.4 |
$4.14 |
46.48 |
"Installed 2005 Prius Thermal tank and ancillary equipment." |
2023-07-04 |
109.1 |
2.2 |
$4.05 |
49.59 |
"Continuing to refine hypermiling techniques." |
2023-07-16 |
116.1 |
2.2 |
$4.04 |
52.77 |
"Continuing to refine my efficient driving style.
Optimized driving route.
Tire pressure 44, had to plug one leaking rear tire this week." |
2023-09-03 |
504.7 |
9.9 |
$4.14 |
50.98 |
"Full tank MPG test." |
2023-10-14 |
522 |
9.7 |
53.81 |
"Second full tank fuel mileage test.
Deep cycle battery.
New LRR tires and new to me Mini Cooper rims.
WINTER setup:
Redline synthetic auto transmission lubricant change in the manual gear box.
0w16 mobil 1 oil change with Frams new synthetic oil filter.
Rerouted thermostatically controlled warm air intake’s inlet to directly above exhaust manifold.
Added circulating 1500watt block heater with wifi timer.
Full grill block.
Insulated engine bay and all coolant lines.
Fire blanket covering engine.
Custom made R-12 engine cover." |
2023-11-03 |
459 |
7.5 |
61.2 |
"Significant fuel mileage improvement with mods listed in last fuel log
Average temps in the mid 40’s" |
2023-11-15 |
6.1 |
62.3 |
"Average temps in the 40’s.
Electric water pump conversion." |
2024-01-13 |
453 |
6.97 |
$3.69 |
64.99 |
"Mid November was last fill.
80% city driving.
Completed under belly covers.
Adjusted warm air intake up to 120 degrees.
Improved engine bay insulation.
Added adjustable grill block vents.
Temps dropping this weekend, lots of snow now also." |
2024-02-14 |
548.35 |
9.97 |
55 |
"With the exception of a couple days it has been a mild winter.
Completed a full power steering delete.
Installed an adjustable grill block.
Reduced weight ~50 additional pounds.
Received screw on aluminum wheel discs from Hub Cap Mike." |
2024-02-14 |
548.35 |
9.97 |
55 |
2024-03-02 |
95.3 |
1.541 |
$4.14 |
61.84 |
"Topped off before trip. 17 degrees to 70 degrees over the past 2 weeks" |
2024-03-02 |
95.3 |
1.541 |
$4.14 |
61.84 |
2024-04-14 |
339 |
5.2 |
$4.05 |
65.19 |
"Summer tires and wheel discs are on." |
