2010-04-08 |
334.2 |
10.375 |
32.21 |
"Initial refueling. Odometer read 31.5 miles at time of purchase." |
2010-04-21 |
363.5 |
10.544 |
34.47 |
"Pretty typical driving. Engine is still breaking in." |
2010-05-01 |
300.6 |
8.869 |
$2.769 |
33.89 |
"YMCA included (3/4 passengers)" |
2010-05-01 |
52 |
1.226 |
$2.769 |
42.41 |
"Highway test: Wendy's and back -- 65 mph on interstate, 55 mph highway" |
2010-05-12 |
334.4 |
9.527 |
$2.769 |
35.1 |
"Some full-throttle acceleration." |
2010-05-23 |
386.5 |
10.029 |
$2.689 |
38.54 |
"Some heavy A/C use; great deal of medium trips" |
2010-06-02 |
344.7 |
9.447 |
36.49 |
"Moderate to heavy A/C use for most of tank. Some full-throttle starts. Stopped using cruise control with about half of the tank left." |
2010-06-12 |
412.4 |
10.227 |
$2.509 |
40.32 |
"Thirty miles of 70 mph interstate, but most of the tank was 55 mph highway cruising. A/C wasn't used much on second half of tank." |
2010-06-29 |
452.1 |
10.403 |
43.46 |
"Mainly 50 mph highway driving without cruise control. Light A/C use. Refueled with 87 octane." |
2010-07-14 |
468.6 |
10.63 |
44.08 |
"Mainly 45-50 mph highway driving, but some city driving included. Approximately thirty miles of 65-70 mph interstate driving. It appears that 87 octane performs just as well as 89 octane, but I'm going to use 89 because it is cheaper by ten cents a gallon. Great tank overall with light A/C use." |
2010-08-06 |
454.1 |
10.398 |
43.67 |
"Cold tire pressure was increased from door recommendation of 32 psi to 40 psi at 161.2 miles into tank (81 degrees Fahrenheit). Slow driving for most of the tank, save for a trip of approximately 185 miles with two passengers. Extra passengers and cargo added over 360 pounds of extra weight, and to keep them happy I had to drive 55 mph and use A/C. Trip included some hilly and curvy roads that forced engine speed up to 2200-2500 RPM for a while before it leveled out." |
2010-08-20 |
420.9 |
10.9 |
38.61 |
"Experimental tank: Driving style much more aggressive than usual. Shift point was brought up to 2500-2900 RPM instead of the usual 1800-1900 RPM. Highway driving was at 55 mph with cruise control. Sixty total interstate miles at 70 mph. Significantly more city driving than usual. Tires were at 38 psi." |
2010-09-04 |
177.9 |
4.639 |
38.35 |
"Experimental tank: No trips other than the usual commute. Approximate distance is 6.3 miles each way, so over 25% of the total miles were when the engine was still warming up. Driving style was the usual conservative style. This tank shows how much of an impact the engine temperature makes, since so many miles were on a cold engine. Tires were at 38 psi." |
2010-09-06 |
51.8 |
1.207 |
42.92 |
"Experimental tank: Drove a short trip that I take somewhat frequently. Results are higher than I expected, considering the number of stoplights in parts of the trip." |
2010-09-24 |
422.1 |
10.882 |
38.79 |
"Mostly commuting with two or three short trips. On tanks such as this, it is really emphasized how MPG values aren't always the best way to express fuel consumption. The more I drive, the better my numbers will be, but I'm using more fuel. Cutting back on driving actually saves more fuel, even if MPG values are lower as a result of only taking short trips (usual commute)." |
2010-10-19 |
433 |
11.025 |
$2.789 |
39.27 |
"Again, mostly commuting with a few short trips. Morning temperatures are dropping." |
2010-11-03 |
408.5 |
10.97 |
$2.789 |
37.24 |
"More trips this tank than the previous two. Morning temperatures are cold, so the engine doesn't get fully warm until less than two miles of the commute remain. Road construction forced over two extra city miles to be added to the daily commute at the beginning of this tank." |
2010-11-27 |
11.094 |
36.51 |
"Efficiency numbers are continuing to drop with the weather. Mainly commuting." |
2010-12-16 |
319.7 |
10.617 |
30.11 |
"Purely winter commuting. Tank included subzero temperatures and an abundance of snow driving. Tires are down to about 33 psi for increased traction in snow." |
2010-12-29 |
334.1 |
10.038 |
$3.099 |
33.28 |
"Tank included sixty total interstate miles at 70 mph. Car was stuck in a snowy driveway for a while. Oil was changed at 303.6 miles into this tank (6878 total miles)." |
2011-01-15 |
252.3 |
8.488 |
$3.099 |
29.72 |
"This is what happens when the car is stuck in snow and idles/revs at high speeds for about an hour. Tires are at 32 psi." |
2011-01-21 |
171.5 |
5.704 |
$3.149 |
30.07 |
"Tank included thirty miles of interstate driving. Extremely cold temperatures were present in this tank. The coldest cold start was at about -17°F/-27.2°C." |
2011-01-31 |
349.6 |
10.716 |
$3.149 |
32.62 |
"Over half of the miles were from a highway trip. Winter is still in full force." |
2011-02-13 |
340.7 |
11.164 |
30.52 |
"Temperatures were quite cold until the end of the tank. Some interstate driving was included. Icy roads burned through some fuel in a fight for traction." |
2011-02-25 |
312.1 |
9.818 |
31.79 |
"First few days of the tank were warm for winter. This was pretty typical winter driving. Gas prices are skyrocketing." |
2011-03-14 |
314.4 |
10.124 |
31.05 |
"I managed to fill up on the day the prices went down ten cents. This tank had a short interstate trip. The rest was typical commuting." |
2011-04-02 |
369.4 |
10.886 |
33.93 |
"Spring may be here, but the temperatures are still pretty low -- especially in the morning. This tank probably had more aimless city cruising than usual." |
2011-04-16 |
313.1 |
8.678 |
36.08 |
"This tank had pretty warm weather until it snowed at the end. Driving was pretty typical." |
2011-05-09 |
366 |
10.831 |
33.79 |
"Snow was on the car at the beginning of the tank. The beginning portion of the tank included some moderately aggressive driving. Weather was cold for spring." |
2011-05-28 |
371 |
$3.809 |
34.67 |
"This tank was primarily commuting. One day included spirited driving. It should be noted that this was a tank of 10% ethanol. Weather conditions weren't very warm in the mornings." |
2011-05-28 |
57.8 |
1.32 |
$3.809 |
43.79 |
"Test tank: This tank consisted of 37 interstate miles at 70 MPH and 13 highway miles at 55 MPH, with the remainder being city miles. City traffic was very heavy with many traffic lights, so economy numbers are higher than expected." |
2011-06-19 |
367.2 |
8.591 |
42.74 |
"This tank had three short trips, while the rest of the tank was the typical commuting route (albeit at slower speeds than usual)." |
2011-06-20 |
296.6 |
6.853 |
$3.539 |
43.28 |
"This is the ""there"" portion of a highway trip. Speeds were kept at 65 MPH for most freeway segments. The end of the tank was all city driving." |
2011-06-20 |
278.9 |
6.245 |
44.66 |
"This is the ""back"" portion of the highway trip. Minimal city driving was in this portion. Speeds were slightly slower on one highway stretch. Total trip MPG was 43.94 MPG." |
2011-07-11 |
444.5 |
10.638 |
41.78 |
"This tank was mostly very short trips. Many miles were at 10 MPH. Some days required A/C use." |
2011-08-04 |
447.9 |
10.43 |
$3.629 |
42.94 |
"This tank was driven at normal speeds. An oil change and tire rotation were performed 120.3 miles into the tank (7/18/11) with a total odometer reading of 11,634 miles." |
2011-08-18 |
398.6 |
9.678 |
41.19 |
"This tank had more interstate speeds and city driving than usual. Hot temperatures warranted high A/C use at times. This was a speed limit tank." |
2011-09-02 |
397.9 |
9.863 |
40.34 |
"Mostly highway driving with around thirty city miles. The car was full of luggage for the first 300 miles." |
2011-09-02 |
247.6 |
5.352 |
46.26 |
"Almost purely highway driving -- a few short city segments were thrown in. A/C use was moderately high for most of the trip." |
2011-09-25 |
397.3 |
10.106 |
39.31 |
"Highway driving for the first part of the tank, mixed with an excess of short city trips." |
2011-12-19 |
454.4 |
13.851 |
$3.16 |
32.81 |
"Statistics are listed for a combination of two fill-ups (one partial fill and a top-off).
First fill (12/15/11):
6.081 gallons
$3.289/gallon
$20.00
336.5 miles
Second fill (12/19/11):
7.770 gallons
$3.059/gallon
$23.77
117.9 miles
Gasoline was old, many short city trips were made, and a highway run was made with a strong headwind throughout." |
2012-01-04 |
318 |
9.783 |
32.51 |
"This tank was primarily winter commuting, with a few other short trips thrown in. Snow was minimal, but defrosting was necessary many cold mornings." |
2012-01-07 |
123.9 |
3.823 |
32.41 |
"This is a top-off that included a high degree of winter commuting, as well as a tire fix." |
2012-01-28 |
354.7 |
9.879 |
$3.049 |
35.9 |
"Primarily highway driving with quite a few short city trips. Winter weather required some heavy defrosting at times." |
2012-03-24 |
203.8 |
6.205 |
$3.589 |
32.84 |
"A highway trip with a packed car, which included a significant portion of city driving." |
2012-05-02 |
353.3 |
8.695 |
$3.439 |
40.63 |
"A highway trip with multiple passengers, some city driving, and part of a highway trip with a car full of luggage." |
2012-05-03 |
146.9 |
3.349 |
43.86 |
"The second half of the return trip, full of luggage." |
2012-05-22 |
399.7 |
10.823 |
36.93 |
"This is the start of summer commuting. Most trips were very short." |
2012-06-15 |
383.1 |
10.584 |
$3.539 |
36.2 |
"Mostly commuting -- very short trips." |
2012-06-15 |
328.3 |
7.193 |
45.64 |
"This is the first part of a highway trip. The car was only brought to a full halt once before stopping for gas. Weather was pretty hot, and the trip was downhill overall." |
2012-06-17 |
242.9 |
5.959 |
40.76 |
"This is the second part of the trip. This is a mix of highway and city driving." |
2012-06-17 |
320.5 |
6.784 |
47.24 |
"This is the final part of the highway trip. Stops were very short -- mostly for construction. Some drafting was done in the last 65 miles or so. This part of the journey was gradually uphill in moderately hot weather with a tailwind." |
2012-07-03 |
334.1 |
35.92 |
"Mostly commuting with hot temperatures that forced somewhat heavy A/C use." |
2012-07-12 |
152 |
4.06 |
37.44 |
"Mostly commuting." |
2012-07-15 |
368.6 |
9.194 |
40.09 |
"Highway driving at 70 miles per hour, plus a very short city section." |
2012-07-15 |
274.9 |
6.176 |
44.51 |
"The final part of the return trip. Highway driving at 70 miles per hour." |
2012-08-13 |
414.5 |
10.825 |
38.29 |
"Mostly commuting. Oil change at 18,300 miles." |
2012-08-20 |
153.2 |
4.321 |
35.45 |
"Commuting with another trip added in near the end of this short tank." |
2012-09-07 |
341 |
8.592 |
39.69 |
"Traveling with a full load, plus short city trips." |
2012-10-09 |
10.979 |
$3.589 |
34.61 |
"One medium-length trip with many short trips and city driving." |
2012-11-25 |
387 |
10.042 |
38.54 |
"Primarily highway miles with some winter-like starts." |
2012-12-13 |
299.8 |
7.668 |
39.1 |
"Mostly a highway tank with some city driving." |
2012-12-13 |
280.2 |
6.824 |
41.06 |
"Highway driving with one stop." |
2013-01-13 |
282.1 |
9.239 |
$3.039 |
30.53 |
"Many cold starts and defrosting periods this tank." |
2013-02-02 |
320.5 |
8.729 |
36.72 |
"One long trip with a few short trips thrown in. Cold temperatures called for some idling and defrosting." |
2013-03-08 |
91.5 |
3.144 |
$3.509 |
29.1 |
"Winter driving with short trips and idling." |
2013-03-10 |
386.2 |
10.111 |
38.2 |
"Driving home, plus some local driving." |
2013-03-12 |
335.4 |
8.992 |
37.3 |
"One highway trip in snowy conditions for part of the trip. Winds were strong at times." |
2013-03-17 |
333 |
9.797 |
33.99 |
"The return voyage, which included blowing snow conditions." |
2013-05-11 |
329.8 |
9.609 |
34.32 |
"Highway driving with many short trips included." |
2013-05-15 |
374 |
10.381 |
36.03 |
"Long trip with a full car, plus a few shorter trips." |
2013-06-04 |
428.2 |
10.913 |
39.24 |
"Mostly commuting. Many rainy days, plus somewhat cold temperatures in the morning." |
2013-06-18 |
392.8 |
9.315 |
42.17 |
"Primarily commuting, with a few other short trips. Tire pressure was increased near the end of the tank. Wet/rainy conditions were common over the life of this tank." |
2013-06-30 |
430.9 |
10.18 |
$3.439 |
42.33 |
"Primarily commuting, with one medium-length trip. Temperatures were higher near the end of the tank." |
2013-07-12 |
351.3 |
8.278 |
42.44 |
"Mostly commuting. My summer daily driving seems to be pretty consistent." |
2013-07-14 |
301.2 |
8.248 |
36.52 |
"This was a primarily highway trip. Most of the way there was in very heavy rain at variable speeds -- it was probably also quite windy. The return trip was dry, but it wasn't able to make up for the bad conditions on the trip there." |
2013-08-02 |
436.8 |
10.288 |
42.46 |
"Primarily commuting in mostly warm weather." |
2013-08-14 |
413.7 |
9.913 |
$3.439 |
41.73 |
"Last tank for the summer of commuting -- filled up on final day of work. Again, this was primarily commuting." |
2013-08-22 |
418.8 |
10.563 |
39.65 |
"One long highway trip, mixed with one medium-length trip and many small town runs. This tank begins a stretch of primarily city driving." |
2013-09-21 |
370.9 |
9.526 |
38.94 |
"Over 60 miles of primarily city driving -- extremely short trips. The remainder of the tank was highway driving." |
2013-09-22 |
410.4 |
9.239 |
$3.029 |
44.42 |
"Primarily highway driving (Chicago trip). There was a stint of very slow driving due to road construction, plus some city portions. Cheap gas price is due to rewards -- $3.289 per gallon minus $0.26 per gallon discount." |
2013-09-28 |
114.1 |
2.584 |
$3.189 |
44.16 |
"Nearly all highway driving across state lines. Rainy conditions were present on the return trip." |
2013-10-13 |
415.9 |
9.694 |
42.9 |
"Some city driving paired with one long highway trip and two shorter trips. Weather was mostly warm, except for some cold mornings.
Actual price per gallon before $0.11 rewards was $3.449." |
2013-11-12 |
338.6 |
8.181 |
41.39 |
"Highway trip paired with multiple short city trips. Temperatures were approximately freezing on the day of fill-up.
Actual price per gallon before $0.10 rewards was $2.799." |
2013-11-24 |
320.1 |
9.36 |
34.2 |
"A small portion of mostly city driving, plus the return journey. Temperatures were below freezing, and two starts required defrosting." |
2013-11-24 |
272.7 |
7.528 |
$3.009 |
36.22 |
"Highway trip (to the capital city and back) with a small section of city driving. Temperatures were below freezing, and the journey there included a strong headwind." |
2013-11-30 |
86.2 |
2.554 |
33.75 |
"Top-off before highway trip. Weather was cold." |
2013-12-13 |
309.6 |
7.743 |
$2.829 |
39.98 |
"Primarily highway driving, plus some driving in cold weather for very short trips." |
2013-12-13 |
280 |
7.157 |
$2.969 |
39.12 |
"Highway driving. Roads were wet and rainy (but not quite frozen) for the first fifth of the trip, with cold, dry conditions for the remainder." |
2014-01-12 |
275.5 |
8.673 |
$3.119 |
31.77 |
"Many short trips in bitterly cold weather with defrosting periods. Two medium trips with city driving were included, but most trips were short and in the cold." |
2014-01-12 |
7.746 |
38.86 |
"Highway driving into a headwind, with mostly dry roads. Temperatures were slightly above freezing, most likely increasing as the trip progressed.
Actual price per gallon before $0.14 rewards was $2.999." |
2014-03-07 |
257.5 |
8.283 |
$3.449 |
31.09 |
"Slightly over a quarter of this fill was winter city driving -- very short trips with very cold starts. The remainder was highway driving in moderately cold (and windy) weather." |
2014-03-16 |
147.1 |
4.688 |
$3.449 |
31.38 |
"A majority of the miles were highway miles, but a portion of the tank included wet/frozen roads. Temperatures were mostly cold, with a few short trips with cold starts." |
2014-03-16 |
298 |
7.617 |
$3.329 |
39.12 |
"Highway driving with wind and temperatures at or below the freezing point." |
2014-04-13 |
149 |
5.164 |
$3.309 |
28.85 |
"An abundance of city driving (short trips) plus one other trip. (Although this tank didn't include the coldest of cold starts, the low gas mileage isn't surprising due to the number of very short trips.)
Actual price per gallon before $0.09 rewards was $3.399." |
2014-04-21 |
305.2 |
7.386 |
41.32 |
"Primarily highway driving in moderately warm weather." |
2014-04-23 |
285.4 |
6.5 |
43.91 |
"Highway driving in moderately warm weather. Some portions were slightly damp, but not wet.
Actual price per gallon before $0.04 rewards was $3.399." |
2014-05-09 |
9.608 |
$3.409 |
35.91 |
"Primarily highway driving with a full car. Over 60 miles were short city trips." |
2014-05-13 |
335.1 |
8.334 |
$3.409 |
40.21 |
"Mostly highway driving with some wet spots, as well as some city driving." |
2014-05-14 |
220.8 |
5.932 |
37.22 |
"Highway driving with long city stalling included." |
2014-05-17 |
328.3 |
7.975 |
$3.369 |
41.17 |
"Highway driving with a small portion of city driving/stopping." |
2014-05-19 |
316.6 |
7.048 |
$3.409 |
44.92 |
"Highway driving slightly below the speed limit with light A/C use at times." |
2014-05-22 |
283.4 |
6.867 |
41.27 |
"Commuting with some trips thrown in." |
2014-06-08 |
338.6 |
8.691 |
38.96 |
"Primarily commuting, which means a bunch of short trips." |
2014-06-25 |
306.5 |
8.536 |
35.91 |
"Primarily commuting, plus bike shopping." |
2014-06-28 |
305.4 |
7.658 |
39.88 |
"Wedding driving, which included many short city trips and highway (airport) driving." |
2014-07-12 |
238.4 |
6.366 |
37.45 |
"Primarily commuting." |
2014-07-24 |
415.9 |
10.828 |
38.41 |
"Airport trip plus commuting. Oil change and tire change (Cooper CS4) near end of tank.
(The tire change was at approximately 34,400 miles.)" |
2014-07-27 |
217.8 |
5.514 |
39.5 |
"Primarily a shopping (highway) run with some slightly wet conditions." |
2014-08-14 |
362.1 |
10.445 |
34.67 |
"Commuting with some other trips." |
2014-09-26 |
411.5 |
10.755 |
$3.139 |
38.26 |
"Suit pickup plus a moving run (loaded car) with city driving." |
2014-10-16 |
385.3 |
10.285 |
37.46 |
"A trip to a slide, a trip home, and a trip to a high point." |
2014-11-02 |
359.7 |
10.19 |
35.3 |
"Some short trips, plus a return voyage in a strong headwind. Morning temperatures started reaching the freezing point near the end of the tank." |
2014-11-24 |
356.7 |
10.022 |
35.59 |
"A rainy drive west, plus a chilly and windy drive north." |
2014-11-24 |
133.3 |
4.196 |
31.77 |
"Top-off after a windy (25+ mph headwinds) drive home." |
2014-11-30 |
337.9 |
8.605 |
39.27 |
"Traveling back with a tailwind for a good portion of the trip. Temperatures were at or slightly below the freezing point.
36,995 miles
4 bars, no light
87
(Lifetime odometer reading, fuel gauge position, and octane used to refill tank.)" |
2015-01-11 |
144.6 |
5.444 |
26.56 |
"Deer was hit at 37,051 miles on the odometer, so fuel was wasted idling afterward and during the repair process. Additionally, winter driving led to low mileage.
37,139 miles
10 bars, no light
87+" |
2015-01-11 |
280.8 |
7.213 |
$1.839 |
38.93 |
"The southbound journey at temperatures hovering right around the freezing point. Roads were wet for the final 30 miles of the tank.
37,420
7 bars, no light
87 (Not sure if 87+ - P.A.D.)" |
2015-02-08 |
243.3 |
7.825 |
31.09 |
"Trip to airport, plus part of the way back. Temperatures were well below 0°F when starting the journey, so cold temperatures contributed to the low mileage.
37,663
6 bars, no light
87 (Shell)" |
2015-02-09 |
125.7 |
3.248 |
38.7 |
"The remainder of the return journey from the airport. Temperatures were moderately cold (slightly above freezing).
37,789
14 bars, no light
87" |
2015-03-05 |
81.1 |
3.574 |
$2.259 |
22.69 |
"Primarily winter city driving - very short trips, so engine was not warm for much of this small portion of a tank.
37,870
14 bars, no light
2015-03-15 |
340.2 |
9.273 |
36.69 |
"Primarily highway driving in spring weather with a decent amount of luggage.
38,211
3 bars, no light
87+" |
2015-03-15 |
283.7 |
8.183 |
$2.189 |
34.67 |
"Highway driving in warm spring weather into a strong headwind. Only a few miles of city driving.
38,494
6 bars, no light
87 (with 10% or less ethanol)" |
2015-04-03 |
271.8 |
8.469 |
32.09 |
"Over fifty miles of city-like driving plus highway driving into a strong headwind (20-25+ mph). Weather was mild spring weather.
38,766
5 bars, no light
87+ (Shell)" |
2015-04-06 |
134.4 |
3.933 |
34.17 |
"Primarily highway driving with strong/moderate headwind.
38,901
13 bars, no light
87+ (Shell)" |
2015-04-06 |
225.9 |
5.796 |
$2.159 |
38.98 |
"Highway driving into moderate headwinds (~10 mph) in mild weather.
39,127
9 bars, no light
87 (BP)" |
2015-05-09 |
308.3 |
9.068 |
34 |
"Substantial portion of city driving, plus a car full of luggage.
39,435
4 bars, no light
87+" |
2015-05-30 |
294.2 |
8.766 |
$2.949 |
33.56 |
"Mostly commuting (short trips) in mild and warming weather.
39,729
5 bars
87 (on accident -- meant to get 87+ and spent an extra $0.30/gallon)" |
2015-05-30 |
157.2 |
3.843 |
40.91 |
"Airport trip. Highway speeds with some wind and very light A/C.
39,886
13 bars
87+" |
2015-06-16 |
347.5 |
9.758 |
$2.589 |
35.61 |
"Mostly commuting, plus a bicycle trip.
40,234
3 bars
87+" |
2015-07-13 |
296.3 |
8.961 |
$2.589 |
33.07 |
40,630
4 bars
87+" |
2015-08-06 |
277 |
8.371 |
33.09 |
"Mostly commuting with A/C. Oil change and body work (remove door ding and repaint driver's front door; repaint rear bumper on driver's side where paint was scraped in Truman parking lot) done at 40,762 miles.
40,807
5 bars
87+" |
2015-08-23 |
353.1 |
9.538 |
$2.309 |
37.02 |
"Moving, plus an ample amount of short city trips. Temperatures are warm.
41,161
3 bars
87" |
2015-11-21 |
150.5 |
6.748 |
$1.969 |
22.3 |
"Almost purely city driving over a three-month period.
41,311
8 bars
87+" |
2015-11-24 |
312.5 |
9.144 |
34.18 |
"Driving home into a headwind, plus half a trip. Temperatures were cold.
41,624
4 bars
87+" |
2015-11-27 |
353.7 |
9.19 |
$1.849 |
38.49 |
"Primarily driving ""back"" with a tailwind. Some city driving was included at the end, and a trip and a half were included at the beginning. Savings of $0.05/gallon brought the price down from $1.899 to $1.849.
41,977
4 bars
87(+?)" |
2015-12-30 |
331 |
9.393 |
$1.749 |
35.24 |
"Return trip with some luggage in cold weather, plus an interview run and some idling in the snow.
42,308
3 bars
87+" |
2016-01-07 |
198.2 |
5.929 |
$1.799 |
33.43 |
"Winter driving, including part of a trip ""back"" on wet roads and into a headwind.
42,507
9 bars
87+" |
2016-03-03 |
282.6 |
10.233 |
$1.659 |
27.62 |
"Part of a trip ""back"" on wet roads and into a headwind, plus nearly two months of short (winter) trips in town.
42,789
2 bars, light
87" |
2016-03-11 |
377.9 |
10.15 |
$1.949 |
37.23 |
"Driving home in a moderately strong headwind, plus some winter/spring driving.
43,167
1 bar, light
87+" |
2016-03-25 |
307.3 |
8.958 |
$1.759 |
34.3 |
"Drive back (probably in a headwind), plus a good chunk of city driving (very short trips).
43,754
4 bars
87" |
2016-03-25 |
279 |
6.477 |
43.08 |
"Highway driving with a tailwind.
43,754
8 bars
87+" |
2016-04-28 |
348.1 |
10.071 |
$1.899 |
34.56 |
"Driving south with a headwind, plus numerous short city trips.
44,102
2 bars
87" |
2016-05-08 |
308.3 |
8.642 |
35.67 |
"Driving north into the wind with a full load (moving).
44,410
5 bars
87+" |
2016-05-30 |
347.2 |
9.824 |
$2.259 |
35.34 |
"Medium-length trips and short town trips, including some rain.
44,757
3 bars
87+" |
2016-06-10 |
353.3 |
9.519 |
$2.259 |
37.12 |
"Mostly commuting with some short city trips.
45,111
3 bars
87+" |
2016-06-20 |
295.4 |
7.854 |
$2.259 |
37.61 |
"Mostly commuting with some short city trips. A/C used most or all trips due to warm weather.
45,406
6 bars
87+" |
2016-06-22 |
291.3 |
7.529 |
$2.259 |
38.69 |
"Training trip with mostly highway miles, along with idling in the city with high temperatures.
45,698
7 bars
87+" |
2016-07-04 |
315.6 |
8.406 |
37.54 |
"Primarily commuting with short city trips.
46,013
5 bars
87+" |
2016-08-08 |
301.9 |
10.319 |
29.26 |
"Primarily commuting (very short trips).
46,315
2 bars, light
87+" |
2016-09-11 |
266.1 |
9.403 |
28.3 |
46,582
3 bars
87+" |
2016-09-21 |
124.8 |
4.247 |
$2.139 |
29.39 |
"Mostly commuting.
46,706
13 bars
87+" |
2016-09-22 |
288.2 |
7.58 |
$2.139 |
38.02 |
"Primarily highway driving (in rainy conditions for one leg of the trip) with some city driving.
46,995
7 bars
87+" |
2016-10-05 |
142.6 |
4.873 |
$2.139 |
29.26 |
"Commuting and other short trips.
47,137
12 bars
87+" |
2016-10-06 |
280 |
6.529 |
$2.179 |
42.89 |
"Highway driving.
47,417
8 bars
87+" |
2016-11-06 |
283.3 |
9.595 |
29.53 |
"Mostly commuting.
47,701
3 bars
87+" |
2016-11-17 |
362.6 |
10.557 |
34.35 |
"Commuting with some medium-length trips thrown in.
48,063
2 bars, light
87+" |
2016-12-04 |
301.3 |
9.86 |
30.56 |
"Commuting in cold weather.
48,365
3 bars
87+" |
2016-12-25 |
217.8 |
9.189 |
23.7 |
"Winter commuting.
48,582
4 bars
87+" |
2017-01-11 |
199.7 |
8.754 |
22.81 |
"Winter commuting with almost purely city miles.
48,782
5 bars
87+" |
2017-02-04 |
222.1 |
9.703 |
22.89 |
"Winter commuting.
49,004
3 bars
87+" |
2017-03-13 |
181.2 |
9.292 |
19.5 |
"Winter commuting.
49,186
3 bars
87+" |
2017-04-05 |
229.9 |
8.885 |
$2.249 |
25.88 |
"Mostly commuting.
49,416
4 bars
87+" |
2017-04-22 |
105.2 |
4.694 |
22.41 |
"Mostly commuting.
49,521
12 bars
87+" |
2017-04-23 |
307.1 |
7.859 |
39.08 |
"Primarily highway driving.
49,828
6 bars
87+" |
2017-04-28 |
225.2 |
6.107 |
36.88 |
"Mostly highway driving, along with a week of commuting.
50,053
9 bars
87+" |
2017-04-29 |
230.8 |
5.961 |
38.72 |
"Mostly highway driving.
50,284
9 bars
87+" |
2017-06-03 |
299.1 |
10.353 |
$2.259 |
28.89 |
"Mostly commuting with some highway driving.
50,583
2 bars, light
87+" |
2017-07-01 |
140.9 |
5.758 |
24.47 |
"Mostly commuting.
50,724
10 bars
87+" |
2017-07-02 |
305.2 |
7.627 |
40.02 |
51,030
7 bars
87+" |
2017-08-12 |
321.2 |
10.911 |
29.44 |
"Lots of commuting.
51,351
1 bar, light
87+" |
2017-09-04 |
384.4 |
11.003 |
34.94 |
"Commuting with some highway driving.
51,735
0 bars, light
87+" |
2017-10-07 |
308.6 |
10.231 |
30.16 |
"Mostly commuting.
52,044
2 bars, light
87+" |
2017-11-06 |
259.9 |
27.36 |
"Mostly commuting in increasingly colder temperatures.
52,304
3 bars
87+" |
2017-12-10 |
233.4 |
10.315 |
22.63 |
"Mostly commuting in the cold.
52,537
2 bars, light
87+" |
2018-01-06 |
232.3 |
10.231 |
22.71 |
"Mostly commuting in the winter.
52,770
2 bars, light
87+" |
2018-02-01 |
222.5 |
10.162 |
21.9 |
"Winter commuting.
52,992
87+
2 bars, light" |
2018-02-15 |
91.7 |
5.084 |
18.04 |
"Idling and commuting in winter conditions. I'll commute one more day before going on a trip.
53,084
11 bars
87+" |
2018-02-17 |
326.9 |
9.65 |
33.88 |
"Stop one on trip. Mostly highway driving.
53,411
3 bars
87+" |
2018-02-17 |
336.1 |
8.41 |
39.96 |
"Highway driving with a brief detour.
53,747
4 bars
87" |
2018-02-23 |
287.2 |
9.1 |
$2.259 |
31.56 |
"City driving (stop and go) and some highway miles.
54,034
3 bars
87" |
2018-02-23 |
295.3 |
8.073 |
$2.159 |
36.58 |
"Highway driving, for the most part.
54,330
5 bars
87" |
2018-02-23 |
355.2 |
9.797 |
36.26 |
"Final leg of trip. Highway driving.
54,685
1,601 trip miles
Unsure on bars - likely low
87+" |
2018-03-10 |
300.4 |
10.375 |
$2.549 |
28.95 |
"Mostly commuting and driving near home. (Not part of a trip.)
54,985
2 bars, light
87+" |
2018-03-15 |
74.3 |
2.633 |
$2.549 |
28.22 |
"Mostly commuting. Tank top-off before trip. Temperatures are still cold.
55,060
16 bars
87+" |
2018-03-16 |
320.1 |
9.364 |
$2.249 |
34.18 |
"Highway driving with headwind.
55,380
3 bars
87" |
2018-03-18 |
221 |
6.099 |
$2.249 |
36.24 |
"Mix of highway and city driving on trip.
55,601
Many bars
87" |
2018-03-18 |
386.6 |
9.193 |
$2.549 |
42.05 |
"Drive back with some tailwind. Highway driving.
55,988
(Unsure on fuel bars remaining)
87+
927.8 trip miles" |
2018-04-20 |
235.3 |
9.835 |
$2.549 |
23.92 |
"Ditch.
Mostly commuting in continued winter conditions.
56,223
3 bars
87+" |
2018-04-22 |
386.4 |
10.146 |
$2.549 |
38.08 |
"Weekend trip, plus some extra driving. Mostly highway with some city in the middle.
56,609
2 bars, light
87+" |
2018-04-29 |
381.7 |
9.783 |
39.02 |
"Highway trip with some city driving.
56,991
3 bars
87+" |
2018-05-07 |
383.5 |
10.372 |
36.97 |
"Highway trip and commuting.
57,375
2 bars, light
87+" |
2018-05-31 |
336.6 |
10.494 |
32.08 |
"Mostly commuting with the occasional shopping trip.
57,711
1 bar, light
87+" |
2018-06-30 |
292.6 |
9.556 |
30.62 |
"Mostly commuting.
58,004
3 bars, no light
87+" |
2018-07-16 |
358 |
10.495 |
34.11 |
"Mostly commuting, along with a three-trip local journey one weekend.
58,362
2 bars, light
87+" |
2018-08-09 |
363.8 |
10.408 |
34.95 |
"Highway trip and lots of short commuting trips.
58,726
2 bars, light
87+" |
2018-09-10 |
293.7 |
10.014 |
29.33 |
"Mostly commuting.
The A/C may be acting up again when under high load -- I haven't been able to test it much. I changed the cabin air filter in August and it seemed to help, but it seemed to be weak on 9/10/18.
59,020
2 bars, no light
87+" |
2018-10-20 |
287.9 |
10.653 |
$2.769 |
27.03 |
"Mostly commuting.
59,308
2 bars, light
87+" |
2018-11-11 |
267.5 |
9.363 |
$2.589 |
28.57 |
"Mostly commuting. It's been quite cold lately.
59,575
3 bars
87+" |
2018-12-07 |
220.5 |
9.294 |
23.72 |
"Winter commuting.
59,786
4 bars
87+" |
2019-01-01 |
288.6 |
10.397 |
27.76 |
"Winter commuting. Oil change at 59,980 miles.
60,074
1 bar, light
87+" |
2019-01-23 |
130.9 |
6.154 |
$2.089 |
21.27 |
"Winter commuting -- top-off before trip.
60,205
8 bars
87+" |
2019-01-24 |
153.9 |
4.246 |
36.25 |
"Highway driving in cold and very windy conditions.
60,359
12 bars
87+" |
2019-01-24 |
258 |
8.199 |
$1.949 |
31.47 |
60,617
4 bars
87+" |
2019-01-24 |
213.6 |
6.93 |
30.82 |
"Winter highway driving. Winds started to go down a bit, but much of this leg was still windy.
60,831
7 bars
87+" |
2019-01-26 |
8.442 |
$2.339 |
34.59 |
"Highway driving sandwiching city miles.
61,123
4 bars
87+" |
2019-01-26 |
326.5 |
9.129 |
$1.949 |
35.77 |
61,450
4 bars
87+" |
2019-01-27 |
315.7 |
9.728 |
32.45 |
"Winter highway driving in pretty cold conditions.
61,765
3 bars
87+" |
2019-01-27 |
97.5 |
3.146 |
$2.089 |
30.99 |
"Winter highway driving. This in the final top-off after the trip. I had headwinds for much of the trip overall. Temperatures were low.
Total miles: 1,657.4 mi
Total gallons: 49.82 gal
Overall mpg: 33.27 mpg
61,863
14 bars
87+" |
2019-02-22 |
178.5 |
9.019 |
19.79 |
"Winter commuting.
62,042
4 bars
87+" |
2019-03-19 |
224.7 |
9.249 |
$2.549 |
24.29 |
"Commuting in cold weather. Spring is starting to come around. Passenger airbag recall worked performed just after this fill.
62,266
4 bars
87+" |
2019-04-14 |
272.9 |
9.67 |
28.22 |
"Primarily commuting. Temperatures have warmed up a little at times.
62,539
3 bars
87+" |
2019-05-04 |
281.1 |
9.13 |
30.79 |
"Commuting and a trip.
62,820
4 bars
87+" |
2019-05-12 |
199 |
6.392 |
31.13 |
"Some highway miles and commuting. Topped off tires - rear two were low.
63,019
9 bars
87+" |
2019-06-01 |
306.7 |
9.408 |
32.6 |
"Mostly commuting, plus some highway miles. The A/C had issues on my way home in the heat. It is working now after changing the cabin air filter (which looked like it was in good shape), so I should continue to monitor it. This has happened before.
63,326
3 bars
87+" |
2019-06-14 |
312.7 |
9.929 |
31.49 |
"Some highway driving and commuting.
63,639
3 bars
87+" |
2019-07-08 |
318.6 |
9.44 |
33.75 |
"Mostly commuting with some short trips.
63,958
3 bars
87+" |
2019-08-19 |
265 |
10.404 |
25.47 |
"Mostly commuting.
64,223
1 bar, light
87+" |
2019-09-29 |
241.5 |
9.764 |
$2.389 |
24.73 |
"Mostly commuting.
64,464
3 bars
87+" |
2019-10-31 |
236.2 |
10.273 |
$2.469 |
22.99 |
"Mostly commuting.
64,700
1 bar, light
87+" |
2019-11-29 |
237.5 |
10.305 |
$2.429 |
23.05 |
64,938
1 bar, light
87+" |
2019-12-30 |
211.4 |
9.777 |
21.62 |
"Mostly commuting.
65,149
3 bars
87+" |
2020-02-20 |
142 |
9.914 |
$2.239 |
14.32 |
"Winter commuting.
65,292
3 bars
87+" |
2020-03-15 |
75 |
3.961 |
$2.019 |
18.93 |
"Coronavirus top-off.
Winter/spring commuting.
65,367
Numerous bars
87+" |
2020-05-09 |
216.6 |
10.392 |
$1.749 |
20.84 |
65,583
1 bar, light
87+" |
2020-08-16 |
279.8 |
10.881 |
25.71 |
"Mostly driving around town.
I have been experiencing an oil leak, along with a really leaky driver-rear tire, and a semi-leaky passenger-front tire.
65,863
1 bar, light
87+" |
2020-10-09 |
263.9 |
9.172 |
$1.969 |
28.77 |
"Mostly driving around town, plus some farm driving.
Oil change at 65,875 miles.
Replaced two TPMS stems that were leaking at the same time.
66,127
4 bars
87+" |
2021-03-26 |
203.6 |
9.604 |
21.2 |
"Mostly short trips, including winter driving.
66,331
3 bars
87+" |
2021-07-05 |
287.4 |
10.928 |
26.3 |
"Mostly short trips.
66,618
0 bars, light
87+" |
2021-11-04 |
268.1 |
10.769 |
24.9 |
66,886
0 bars, light
87+" |
2022-05-21 |
208.8 |
9.373 |
22.28 |
"Mostly short trips after the car sat idle for a long time in the spring. The battery is back to keeping enough of a charge to start without a booster pack.
67,095
3 bars
87+" |
2022-07-28 |
316.6 |
9.715 |
32.59 |
"Many short trips and much idling with a low battery. The old battery stopped holding a charge for short periods of time after driving. Battery changed at 67,292 miles (7/23/22).
67,412
3 bars
87+" |
2022-07-31 |
138.8 |
4.204 |
33.02 |
"Primarily a farm tour. I idled in the drive-through. There was some additional mileage added.
67,551
13 bars
87+" |
2022-08-14 |
271.3 |
8.879 |
30.56 |
"I drove on a lot of gravel roads on this tank.
67,822
4 bars
87+" |
2022-09-04 |
267.1 |
9.649 |
27.68 |
"I had a mix of gravel roads and short trips on this tank.
68,089
3 bars
87+" |
2022-09-26 |
332.3 |
10.504 |
31.64 |
"This tank included a mixture of town, gravel, and highway driving.
68,421
1 bar, light
88+" |
2022-10-25 |
264.2 |
9.728 |
27.16 |
"This tank included a lot of farm driving and gravel roads.
68,686
3 bars
87+" |
2023-01-17 |
259.7 |
10.305 |
$3.249 |
25.2 |
"This was mostly short trips in winter weather.
68,945
1 bar, light
87+" |
2023-02-04 |
197.3 |
7.293 |
27.05 |
"Typical driving in cold weather. No trips were very long.
69,143
7 bars
87+" |
2023-02-04 |
75.9 |
1.976 |
38.41 |
"Winter mileage test. Temperatures peaked at 27 ºF. Winds were around 8 mph.
I drove to a dealership lot. Approximately 29 miles were highway miles at 68 to 70 mph. I drove conservatively. I was impressed with this high result in cool weather.
69,219
16 bars
87+" |
2023-03-04 |
322.7 |
10.561 |
30.56 |
"This was winter driving with no journeys that were too long.
69,542
1 bar, light
87+" |
2023-06-19 |
312.8 |
10.843 |
28.85 |
"This was the end of a winter-spring tank from March. The car sat for a while as I worked on polishing the paint.
The driving included a lot of short trips.
69,854
0 bars, light
87+" |
2023-07-09 |
294.5 |
9.13 |
$4.299 |
32.26 |
"I filled up on premium this time because the pump didn't seem to offer anything else at the time.
This driving was pretty typical for the summer.
70,149
4 bars
91" |
2023-07-26 |
326.9 |
9.564 |
34.18 |
"I took more trips to the parts store than usual (but not for this vehicle). This meant that I had a good amount of highway driving at reasonable speeds, but I also had a good amount of city driving (short trips).
I'm not really convinced that my use of premium on the last fill-up made much of a difference other than the fact that it doesn't have any ethanol in it, so I may have reaped an extra mile or two per gallon out of this tank as a result.
70,476
3 bars
87+" |
2023-08-12 |
353.7 |
11.083 |
31.91 |
"Typical summer driving around here, including a farm tour.
70,830
0 bars, light
87+" |
2023-09-04 |
10.203 |
29.5 |
"Typical summer driving, including many short trips in town. Weather has been pretty hot at times, but the A/C may not be fully functional.
71,131
2 bars, light
87+" |
2023-09-15 |
9.941 |
30.68 |
"Typical driving, including plenty of gravel roads.
71,436
3 bars
87+" |
2023-09-29 |
341.3 |
10.185 |
33.51 |
"Typical driving.
71,777
2 bars, light
87+" |
2023-10-10 |
10.258 |
32.17 |
"Typical driving.
72,107
2 bars, light
87+" |
2023-10-29 |
297.1 |
10.275 |
28.91 |
"Typical driving.
72,404
2 bars, light
87+" |
2023-11-13 |
298.3 |
10.268 |
$3.149 |
29.05 |
"Typical driving.
72,702
2 bars, light
87+" |
2023-11-24 |
97.8 |
3.1 |
31.55 |
"Top-off before potentially selling the car or storing it for the winter.
72,800
14 bars
87+
Update: Vehicle sold on 11/30/23 with 72,809 miles and a lifetime fuel economy of 33.87 mpg." |
