2019-01-06 |
182.5 |
2.591 |
$1.899 |
70.44 |
"Slight overfill, no fuel light. Mix of spirited twisties and 70 mph highway." |
2019-03-02 |
222.8 |
2.973 |
$2.189 |
74.94 |
"17/42 gearing for whole tank, however I dicked around with short trips and romping during an exhaust experiment, otherwise this tank would have been better. Fuel light threatened to come on, it blinked for a bit, then stopped. Rear tire hugger also installed." |
2019-03-24 |
194.9 |
2.843 |
68.55 |
"Rode fast-ish paced in group, then had to ride two up for 40 miles when dad’s VFR 800 broke down. He rode for 25 miles. Fuel light did not come on." |
2019-04-02 |
216.2 |
2.718 |
$2.629 |
79.54 |
"40 miles of spirited riding, the rest mostly doing around 60 mph tucked. Fuel light did not come on." |
2019-04-17 |
210.3 |
2.82 |
74.57 |
"Last 60 miles was slow paced group ride without tucking, some highway. Don’t know about everything else. Filled bike on steep incline, may have taken more fuel than it would otherwise. Fuel light did not come on." |
2019-04-26 |
201.4 |
3.23 |
62.35 |
"Me riding for 80 miles." |
2019-04-27 |
124.3 |
2.073 |
59.96 |
"Didn’t ride this tank. Mounted GPS and recorded average speed of 41 mph." |
2019-05-05 |
210.7 |
3.414 |
61.72 |
"Fuel light started blinking(1st stage) at 200.1 miles. I rode maybe 40 miles of this tank. Also spilled a little bit of fuel." |
2019-05-24 |
220.3 |
3.174 |
69.41 |
"Rode to dragstrip in terrible traffic this tank, did 4 passes. Didn't reliably deploy GPS, so no average speed. Fuel light did not come on." |
2019-06-16 |
74.3 |
1.044 |
71.17 |
"Unknown riding. Installed new battery at end of tank." |
2019-06-16 |
180.7 |
2.324 |
77.75 |
"Moderate amount of tucking, group ride. GPS average speed of 44.7 mph." |
2019-06-17 |
285.5 |
3.743 |
$2.529 |
76.28 |
"Moderate amount of tucking. Riding blue ridge parkway. Lots of climbing and descending hills and 50 mph riding. Some hoonery. Fuel light started blinking (1st stage) at 232.0 miles, never went solid. Really thought I was going to hit 80 MPG." |
2019-06-18 |
187.5 |
2.234 |
83.93 |
"Slightly higher speed riding, stuck with group for almost whole tank(corridor effect)." |
2019-06-18 |
128.5 |
1.675 |
76.72 |
"Less tucking." |
2019-06-19 |
126.9 |
1.851 |
68.56 |
"Spirited mountain riding." |
2019-06-19 |
126.3 |
1.628 |
77.58 |
2019-06-19 |
118.8 |
1.66 |
71.57 |
"Analog gallon readout, riding fast in the rain" |
2019-06-20 |
248.7 |
3.41 |
72.93 |
"Dad rode for 70 miles. Fuel light started flashing (1st stage) at 235.2 miles. Higher speed group riding + rain." |
2019-06-21 |
207.2 |
3.027 |
68.45 |
"Fuel light did not turn on, forgot to put this fillup in, but my dad might have been riding this tank." |
2019-08-09 |
240.6 |
3.506 |
68.63 |
"Unknown riding most of tank, ended with lots of idling to switch coolant to distilled water for race track." |
2019-08-10 |
148.4 |
4.019 |
36.92 |
"Racing at Road Atlanta, 8 runs at 20 minutes each. I rode 7, little brother 1. Fuel light was solid for the last few minutes of riding. I hit 139 mph indicated, which is actually 125 mph on the back straight." |
2019-09-29 |
254.9 |
3.449 |
73.91 |
"Mostly efficient riding, lots of 65+ mph highway though. Fuel light started flashing(1st stage) at 231.9 miles. I think I did lots of idling to switch back to coolant this tank, it felt like it should have been higher. I think that is why." |
2019-11-06 |
176.1 |
2.447 |
71.97 |
"Slight overfill, don’t know what kind of riding, no fuel light." |
2019-11-17 |
181.6 |
2.246 |
$2.319 |
80.85 |
"Efficient riding, but not lots of tucking. Following tank filled correctly, previous tank was overfill so this is optimistic. Fuel light did not turn on." |
2019-11-26 |
218.1 |
3.033 |
$2.549 |
71.91 |
"Weather is getting colder, probably winter gas formula now. This tank was fairly efficient riding, lower speeds, decent amount of tucking. Kind of disappointed to only see 71.9. Coolant temperature hanging around mid 160s, need to block off more of the radiator." |
2020-01-12 |
181.6 |
2.551 |
71.19 |
"Installed V strom 650 camshafts and velocity stacks, as well as 2003-2006 SV650 90C thermostat later in this tank. Idled to bleed cooling system. Fuel light did not come on." |
2020-01-12 |
119.4 |
1.588 |
75.19 |
"First tank with all strom cams, stacks, and hotter thermostat. A little dissapointed, but the fillup direction between the last tank and this tank were different (down vs up), plus the newly installed grip heaters were used. Fuel light did not come on." |
2020-03-19 |
230.6 |
3.148 |
$1.939 |
73.25 |
"Full tank with the new mods installed, mostly efficient riding, but not a whole lot of tucking. Fuel light came on and off several times, flashing at 224.1 miles." |
2020-03-28 |
231.5 |
3.251 |
$1.899 |
71.21 |
"Brother rode for 60 miles, fuel light at 226.3 miles." |
2020-03-28 |
92.2 |
1.33 |
$1.679 |
69.32 |
2020-04-17 |
220.7 |
3.32 |
$1.799 |
66.48 |
"Brother riding for later part of tank. Fuel light flashing." |
2020-05-10 |
115.5 |
2.184 |
$1.399 |
52.88 |
"Some of my brother riding, lots of highway." |
2020-06-01 |
135.4 |
3.918 |
$1.699 |
34.56 |
"Road Atlanta track day plus idling for coolant bleeding afterwards. Fuel light was solid (2nd stage)." |
2020-06-18 |
269.5 |
3.868 |
$1.899 |
69.67 |
"Dunlop Q3+ tires on right now, plus brother riding some this tank. Fuel light came on solid." |
2020-06-23 |
211.5 |
2.814 |
75.16 |
"Lone blood mountain runs. Fuel light did not come on." |
2020-06-26 |
254.1 |
3.489 |
$2.179 |
72.83 |
"90 miles of unknown riding, all else 75 mph while tucked. Fuel light turned on at 217.6." |
2020-06-27 |
138.6 |
1.926 |
$1.899 |
71.96 |
"Spirited group riding" |
2020-06-27 |
170.1 |
2.529 |
67.26 |
2020-06-29 |
258.5 |
3.573 |
72.35 |
"Spirited but efficient, filled with ethanol free gas. Some tucking." |
2020-06-29 |
198.2 |
2.778 |
$1.939 |
71.35 |
"Ethanol free gas this tank, 65-75 mph expressway riding without much tucking." |
2020-09-26 |
271.3 |
3.961 |
$1.889 |
68.49 |
"Sat around for a while this tank, some idling without riding. Some tucking, hard accelerating, etc. Attempted a MAP sensor trick to reduce fuel injected, but it didn't work. Fuel light flashing at 209.4 miles, solid at 259 ish." |
2020-10-16 |
178 |
2.303 |
$2.179 |
77.29 |
"Slight overfill, Vstrom ECU installed 20 miles into this tank." |
2020-10-17 |
197.3 |
2.5 |
78.92 |
"Didn't get full numbers for the gallons used before filling the next bike. Gallons should be within 0.1 of the actual number." |
2020-10-18 |
197 |
2.736 |
$1.839 |
72 |
"Brother rode for around 60 miles this tank." |
2020-10-22 |
241 |
3.353 |
$1.989 |
71.88 |
"I rode for around 100 miles efficiently, then others rode the bike. Fuel light did come on." |
2020-12-11 |
135 |
2.236 |
60.38 |
"Brother riding for most of this tank." |
2021-03-07 |
239.2 |
3.582 |
$2.6 |
66.78 |
"Don't know what went on most of this tank, or who was riding. Fuel light flashing at 208.8 miles." |
2021-03-14 |
267.2 |
3.584 |
74.55 |
"Mostly efficient riding, but without much tucking. Fuel light flashing at 244.8 miles. Warmer weather." |
2021-05-01 |
103.9 |
1.882 |
55.21 |
"About 30 miles of low speed turning practice and panic stops, very little tucking as well." |
2021-05-29 |
234.3 |
3.032 |
77.28 |
"Mostly efficient riding with lots of tucking, fuel light turned on at 229.4 miles." |
2021-06-13 |
211.8 |
3.136 |
67.54 |
"Decent amount of tucking, but plenty of hard acceleration, fuel light came on at 209.9 miles." |
2021-07-02 |
219.8 |
2.949 |
74.53 |
"Unsure of what happened this tank. Pump may underreport mileage and inflate MPG, pump line was full of gas and dumped into the tank. Fuel light was not flashing." |
2021-07-03 |
227.7 |
3.122 |
72.93 |
"Lots of tucking at 70 mph, some spirited riding in twisties. Fuel light came on intermittently." |
2021-07-04 |
212.7 |
2.834 |
75.05 |
"Twisty riding with some hard acceleration, and lots of 55 mph speed limit roads." |
2021-08-01 |
266.9 |
3.628 |
$2.909 |
73.57 |
"Some spirited riding, not much tucking, fuel light turned solid shortly before fillup." |
2021-08-07 |
206 |
2.744 |
$2.949 |
75.07 |
"Mostly efficient blood mountain runs with a good amount of tucking." |
2021-09-10 |
259.7 |
3.497 |
$2.929 |
74.26 |
"Unknown riding, fuel light flashing at 231.8 miles" |
2021-10-10 |
110.8 |
1.482 |
74.76 |
"Short fill, don't know what happened this tank." |
2021-10-15 |
176.4 |
2.522 |
$3.099 |
69.94 |
"Blood mountain riding, swapped worn out Michelin Road 5 front tire for Dunlop Q3+. Fuel light not on." |
2021-10-15 |
197.8 |
2.481 |
79.73 |
"Deals gap and slower group riding, fuel light did not come on." |
2021-10-16 |
226.6 |
3.439 |
$3.099 |
65.89 |
"Others rode for some of this tank. Fuel light flashing." |
2021-10-16 |
226.6 |
3.439 |
$3.099 |
65.89 |
"Others riding this tank, fuel light flashing." |
2021-12-28 |
224.3 |
3.356 |
66.84 |
"Pretty sure others were riding this tank, fuel light started flashing at 205.0 miles." |
2022-03-06 |
194.5 |
2.789 |
69.74 |
"Fuel light didn't come on." |
2022-04-11 |
154.5 |
2.245 |
68.82 |
"Some commuting to work, no fuel light." |
2022-04-11 |
220.3 |
3.051 |
$3.689 |
72.21 |
"Long group ride around highway speeds, decent amount of tucking, someone else riding for 20 miles. Fuel light did not turn on." |
2022-04-23 |
214.2 |
2.728 |
78.52 |
"Forgot to put this fillup in. Fuel light did not turn on." |
2022-04-23 |
173.3 |
2.473 |
70.08 |
"Forgot to put this fillup in, fuel light did not turn on." |
2022-05-12 |
240.2 |
3.16 |
$3.909 |
76.01 |
2022-06-07 |
209.6 |
3.067 |
$4.398 |
68.34 |
"Forgot to pull this fillup in, fuel light on at 206.2 miles." |
2022-07-09 |
216.3 |
3.296 |
$4.199 |
65.63 |
"Riding in hot weather and traffic, fuel light flashing at 199.0 miles." |
2022-07-11 |
236.8 |
3.195 |
$4.199 |
74.12 |
"Unknown, fuel light at 224.3 miles." |
2022-07-17 |
219.2 |
3.086 |
$4.119 |
71.03 |
"long highway ride for iron butt prep. Fuel light turned on at 212.8 miles." |
2022-07-17 |
179.8 |
2.619 |
68.65 |
"long highway ride for iron butt prep. No fuel light." |
2022-10-08 |
225.2 |
3.488 |
64.56 |
"Guessing when the fill up happened. Fuel light flashing at 201.9 miles." |
