Old 06-10-2015, 06:44 PM   #51 (permalink)
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Subaru Impreza Outback Sport
90 day: 27.81 mpg (US)
I'm in the process of installing a similar mod on my matrix. Which color wire was it that you cut into?
Redneck Repair forum
Old 06-10-2015, 08:59 PM   #52 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Its a black/ white wire right after the ECU mulit connector. I have a pic above with the OEM and then my addons. if needed I can take some more pics.
Old 06-10-2015, 10:37 PM   #53 (permalink)
Thanks! Does this look right?
Old 06-10-2015, 10:47 PM   #54 (permalink)
Wiki Mod
Im not sure, Tomorrow I will go pull the glove box off and i can tell you the pin out slot I cut into.
Its been 4 years since I messed with it. except for a tactic switch going bad Its been almost issue free
Old 06-10-2015, 10:49 PM   #55 (permalink)
Well, it seems like the right one, I just snipped it with the engine running and it sputtering out.
Old 06-10-2015, 10:51 PM   #56 (permalink)
Wiki Mod
thats the other way of testing, now put some plugs on the ends and and pull it apart and as it starts to die, push it back and if the rpms are above about 500 it will fix its self and keep running
Old 06-10-2015, 10:52 PM   #57 (permalink)
Oh, don't go to any work for me. I think I've got it. I'll install the relay on this wire and see how it goes.
Old 06-11-2015, 10:39 AM   #58 (permalink)
It works! Thanks a bunch!
Old 06-15-2015, 05:12 PM   #59 (permalink)
Originally Posted by Phantom View Post
Good job so can you tell any difference with the injectors off and the throttle closed vs throttle open.
This is not the point of the mod, but I was curious about this too. There is very little if any noticeable difference as to engine breaking, but it's hard to tell. The engine makes more noise and vibration with WOT. Feeling that while flooring it makes it seem like the car is doing something different but it's probably all in my head.
Potential engine mod? Otto to Atkinson conversion AndrewJ EcoModding Central 88 10-24-2022 03:53 AM
Swap XFi engine for current I4? wyatt General Efficiency Discussion 5 07-07-2010 11:38 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
Search Engine Friendly URLs by vBSEO 3.5.2
